Shape to spread over group, not individual heads
htevents
Postby htevents » 24 Jan 2020, 19:31
I have 4 Groups of the same moving heads. 6 (horizontal) by 4 (vertical) fixtures in this case.
I want a left to right movement, where the top 6 heads will move from left to right at the same time, then the heads underneath those 6, and so on. My friend is using Chamsys and he could select if he wanted to spread across the individual fixtures, over groups or within the groups. Can we do something like that in Titan too, without having to record different groups with multiple fixtures having the same fixture number?
sideshowbond
Re: Shape to spread over group, not individual heads
Postby sideshowbond » 02 Feb 2020, 22:45
I'd use a group with a layout set up to match your fixtures. Then add a shape and change the direction to TopDown and set the offset to your taste.
Also I'd do this with a key frame shape and Pan only palettes (recorded via the Record Palette menu, Avo+Palette). You have a lot more tools to play with that way.
Users browsing this forum: No registered users and 1 guest
