worlde easycontrol 9 midi console
debaggerboot
Postby debaggerboot » 29 Jul 2019, 16:47
Dear,
Is it possible to use the worlde easycontrol 9 midi controller with titan?
In the software i can adjust several settings on the buttons and faders.. But inside titan nothing seems to happen...
Kind regards,
Jeroen
phb
Re: worlde easycontrol 9 midi console
Postby phb » 29 Jul 2019, 17:36
Hi Jeroen,
Support for USB MIDI devices on consoles is currently scheduled to be included in the upcoming V12.0 release of Titan. However, USB MIDI will require T2 (or higher) hardware; it will not be available for the TitanOne or T1.
Hope this helps
Best,
Pete Bridgman :: Avolites
debaggerboot
Postby debaggerboot » 29 Jul 2019, 17:40
Dear,
So the titan mobile wont be supported?
phb
Postby phb » 29 Jul 2019, 17:42
USB MIDI will be available on all hardware except TitanOne and T1, so yes, Titan Mobile will be supported.
Best,
debaggerboot
Postby debaggerboot » 29 Jul 2019, 18:06
perfect! thnx for replying.
LordOrange
Postby LordOrange » 23 Aug 2019, 11:58
If you need to use it before Titan V12.0 comes out, you could use a third party app to map the midi inputs to SaCN outputs and use the sacn as triggers. It's a little convoluted but it works.
sideshowbond
Postby sideshowbond » 29 Aug 2019, 10:25
if you want to use USB Midi on the same laptop as the Titan Mobile I can recommend MidiToWeb
https://www.avolites.de/support-downloads/midi-to-web
This simply translates Midi into WebAPI commands
Users browsing this forum: Google [Bot] and 3 guests
