New Member and upgrading
				Posted: 24 Jul 2019, 09:14
				by grollie
				Hello i'm new to titan one and volunteer at church. We have old laptop that's seen better days and failing. we use an older usb dongle with 5 pin xlr tailed wire. Will the dongle run with 11.3 as the dual core laptop has 10.1 win7 home premium and transferring to quad core tower with win 7 pro on it. I already have setup Avolites account to transfer licence. Brill forum thanks from Ken Naunton.
				Re: New Member and upgrading
				Posted: 24 Jul 2019, 10:57
				I don't see any problem.  11.3 is compatible with the dongle and it is always best to run the latest version if possible.  And in the very unlikely event there is a problem you could easily downgrade by uninstalling 11.3 and installing 10.1.  The only thing to be aware of is showfile compatibility:  Shows are not backwards compatible across major versions - in other words if you install v11.3 and save the show and then decide to revert to 10.1 it will not load the show saved in 11.3 (although it will still load any previous shows saved in 10.1 of course).  Also, autosaves only work with the version they are saved in.  So, if you need to load older shows, you will need to make sure you have an 'Initial' or 'Quick' save from 10.1 before trying to load into 11.3.  Worse case scenario is (uninstall 11.3) install 10.1, load, save then install 11.3.
				Posted: 24 Jul 2019, 11:52
				by grollie
				Thankyou for reply i will put 11.3 on pc
