Titan One on Raspberry Pi
JCInfraSom
Postby JCInfraSom » 27 Jun 2019, 11:22
Hello, I was wondering if it is possible to use a Raspberry Pi to install Titan one Software!?
Thanks in advance!
phb
Re: Titan One on Raspberry Pi
Postby phb » 02 Jul 2019, 12:24
Good afternoon,
Titan requires the Microsoft Windows operating system to run (n.b. not the IOT version). As far as I can tell, although Microsoft do produce a build of Windows for the ARM architecture, there seems to be no official support for the Raspberry Pi, which would be the first major roadblock to having this work.
If you did manage to get a full build of Windows running on the Pi, I suspect you would find that the performance of the machine would be significantly below what is required to run Titan satisfactorily (see https://www.avolites.com/software/downl ... tion-notes for more details on the minimum specification required).
If you'd like to run Titan on a single board computer, I'd recommend looking into a x86/x86-64 based system that more closely meets the minimum requirements listed.
Pete Bridgman :: Avolites
Users browsing this forum: Bing [Bot] and 1 guest
