I'm trying to set my flash buttons to have a 0s fade in time and 2s fade out time.
I have it set to 'Timed Flash' I just can't seem to be able to alter the fade times at all.
Is there a flash times menu?
If so how do I access it?
Novice Question: Flash fade time
Re: Novice Question: Flash fade time
You can set them either via [Edit Times]/[Flash Times] or via [Playback Options]/[Playback]
Hi Nic,
I've set a flash fade out time for a cue, but it will not show in capture. It fades out on fader, but not on flash. Any idea why?
Please ensure you have changed your key profile so the button is set to Timed Flash. You can set separate Flash Times as Nic mentioned above although by default they should follow the normal cue fade times, either way you would still need to change the key profile. The Nightclub built in key profile is one you can use for this.
That was the winning answer, thx for the fast reply!
