Remote app
Posted: 10 Nov 2018, 14:36
by Andylights
Remote app won’t see Titan one a real pain, does any one know how to fix, tried everything I think, wifi on and connected, Evan tried wifi hotspot, also firmware I’d flagged up for updat on start up of Titan one could that be the problem? Thank you
Re: Remote app
Posted: 10 Nov 2018, 16:42
by Andylights
Andylights wrote:Remote app won’t see Titan one a real pain, does any one know how to fix, tried everything I think, wifi on and connected, Evan tried wifi hotspot, also firmware has flagged up for update on start up of Titan one could that be the problem? Thank you
Re: Remote app
Posted: 10 Nov 2018, 16:58
by icke_siegen
what is 'everything' that you have tried?
- make sure the remote has the same version as Titan
- try to ping your mobile device from the computer Titan is running at - if this doesn't work then there is a network issue (e.g. conflicting or wrong addresses)
- disable firewall and antivirus (for tests - if this helps add some exceptions for Titan)
S.
Re: Remote app
Posted: 11 Nov 2018, 12:37
by Andylights
Sorted it, I connected the Titan one to my mobile broadband by wifi first then my iPhone to same mobile broadband, then after starting remote app it finally sees Titan One, I was using my iPhone as wifi hotspot which didn’t work, thanks reply... Andylights
Re: Remote app
Posted: 12 Nov 2018, 12:39
by Kully
I would strongly recommend using a private wireless LAN that is not connected to the Internet to avoid potential networking issues.
