Downgrading Titan One
JArcher101
Postby JArcher101 » 26 Sep 2018, 10:20
Is it possible to downgrade Titan one dongle? I run it on V11 on my laptop but my TT is on V9 (can't afford the £1500 motherboard upgrade) and v11 files from my laptop won't transfer to v9 on the desk is it possible to gowngrade the dognle from v11 to 9 and if so is it a case of just getting the firmware off of the Avo site?
Cheers in advance
Re: Downgrading Titan One
Postby niclights » 26 Sep 2018, 10:50
It's just software (rather than firmware). Uninstall v11 from Windows Control Panel and then install v9 (I usually restart in between just to be safe).
sideshowbond
Postby sideshowbond » 26 Sep 2018, 23:33
as Nic says. You need to completely uninstall Titan and reinstall v9.
If you wanna run v11 alongside v9 on your Titan One laptop you could try a tool called Titan Switch which you can find on avolites.de. Make sure to install the lower version first though.
Users browsing this forum: No registered users and 2 guests
