Titan One receive time code and be controlled by other source
Posted: 29 Aug 2018, 11:27
by viktor92
Dear all,
I need to do a simple setup where I need to play audio from a source (analog stereo signal) and trigger time code which will control my Titan One dongle. I would like to know how to make the setup in Titan One to receive time code, and which software you can advice to use. I need a software similar to Qlab, but Windows based.
Many thanks in advance.
Viktor.
Re: Titan One receive time code and be controlled by other source
Posted: 29 Aug 2018, 11:35
by Gregory
Titan can on only receive MIDI (MTC) and SMPTE (LTC) timecode via Avolites hardware which is not present nor available for the TitanOne. The other timecode sources: Internal, Winamp and Clock can be used however are probably not what you want unless you want to use Winamp to play your audio track.
