Using iPad as an extra touch screen
Posted: 15 Jan 2018, 09:26
Hi everyone,
Recently I am trying to run titan one on a 15" Macbook pro with Win 10 system. I figured out it would be nicer to have a touch screen attached when I am programming and running a show, so I am trying to use an 13" iPad Pro as an extra screen.
There is an app called Duet which allows you to make iPad become a touch screen when you connect it to a laptop. The touch function works fine when running the windows and all the other applications. However, touch function just disappear (disable?) after I launch Titan One, but it will work again after I minimize or quit Titan One in Win10. I try with MA on PC as well and it works fine as well.
Did any one try to do this before and have a solution about it?
Thanks a lot!
Thanks a lot!
