Color Wheel Fade
Posted: 07 Oct 2017, 18:13
by kimwida
Hi.
I just want to fade color wheel to blue for 2 seconds.
(or want to scroll color wheel to blue for 2 seconds. => same meaning??)
When I set fade time to 2 seconds, it snap to blue after 2 seconds.
I need smooth color change to blue because fast color spin is not match for slow songs.
I searched the forum and found classic consoles can do it with editing personality file but not Titan.
Is it right??
Re: Color Wheel Fade
Posted: 07 Oct 2017, 18:38
If you mean a fixed colour wheel this will depend on the capability of the fixture as well as the personality. If the fixture has the ability to index the colour wheel (ie. set to any position between adjacent colours) then the personality will usually have a 'Index' function with variable percentage ranges and you should use these. What is the fixture and what exactly are are you trying to fade from/to?
Posted: 08 Oct 2017, 03:32
by kimwida
It's one of 7r beams and I want smooth color change when any color changes.
As you said, using index function (Raw DMX) I can fade fixed color wheel now.
When I made the personality of them, I was curious what for the raw DMX.
Now I knew it.
Thanks!!!
