Playback set to flash
Posted: 29 May 2017, 17:35
by deepain
I've been trying all day to make a playback work like a flash button from the touch screen. I have a playback workspace window with some cues. I want to touch the playback and have it be a flash (only active while I'm touching it). I have made a key profile that is all flash and it does not work. Am I missing something?
Re: Playback set to flash
Posted: 29 May 2017, 17:46
It should work by setting the touch key profile action for the particular type of playback to 'Flash' and either setting the appropriate key profile in playback options for that playback or, if the key profile for that playback is set to 'Global' (default) then with that as the active key profile.
It works testing here on TitanOne v10.1 using the following steps:
- New show
- Patch 1 x dimmer
- Record dimmer at full to a playback workspace handle
- Clear
- Avo+[Edit Current Key Profile]
- [Add User 1] (for this example)
- select the playback handle (to shortcut straight to the relevant key profile options)
- [Flash]
- Exit
= Touch playback handle flashes dimmer.
Posted: 29 May 2017, 22:14
by deepain
Interesting. That works in the new show test. But if I do he same thing in my show it stays as latch
