position lost
Posted: 15 Oct 2016, 17:20
by zahoorjury
hi , while opening a saved show the fixtures position in capture lost , but the playbacks are OK , how to retrieve the fixtures positions as saved in show .
regards
Re: position lost
Posted: 16 Oct 2016, 15:47
by Gregory
If you have a previous copy of the Titan show file where Capture is correct you can export the Capture project file and then you can import it into the current show using the Show tab of the Capture Settings window.
