Hi just download T1 demo version , while looking into capture visualiser I cannot found how to add Object like Stage , Truss , sound speakers etc. And how to adjust the things individually at x , Y or X axis .
Any body can tell ?
Regards
T1, Add objects & material in capture
- zahoorjury
Re: T1, Add objects & material in capture
Currently the only element available is 'Box'. These can be used to create stage, floor and wall etc. Open 'Capture Visualiser Settings' then select the 'Stage' tab. Press the [+] button to add an element. Select the elements to open and ajust properties.
- zahoorjury
Thanks , but how can I adjust the X , Y or Z axis of a patched fixture ?
Select fixture(s), toggle wheels on softkey G until it reads [Wheels=Visualiser]. Then select position attribute group ([P] above the thumbwheels). The thumbwheels now control X/Y/Z position. You can page to orientation and rotation controls by pressing [P] again.
Are there now more objects available or is it still only a box?
Users browsing this forum: No registered users and 7 guests
