Visualizer
theatricalassoc
Visualizer
Postby theatricalassoc » 18 Nov 2012, 23:54
I just download the Titan one to work with before i purchase. I am having trouble getting the visualizer to work with the demo show file. AM i missing a step to get it going?
Postby icke_siegen » 19 Nov 2012, 07:36
What exactly is the problem with it? From what I can see, it works. The only thing is the same issue like in Simulator/consoles with 6.0: the Demo Show has outdated personalities - thus the locate values for the Robe spots are not correct.
theatricalassoc
Postby theatricalassoc » 19 Nov 2012, 14:18
When I try to open the demo theatre or any file, the visualizer does not seem to allow me to open any commands. I cant get to a file and nothing shows up in the visuzlier
Postby icke_siegen » 19 Nov 2012, 14:43
Did you use the context button in the title bar of the visualiser window?
There you can also toggle to 'design mode', and load a theatre.
theatricalassoc
Postby theatricalassoc » 21 Nov 2012, 23:25
Yes, went to the Context button and try to press buttons and nothing happens. I was trying to load theatre, but get no where.
Postby icke_siegen » 22 Nov 2012, 07:20
Wow, that's really weird. At least I haven't heard about such an issue before. So, does the visualiser window open at all?
- which version do you use? 6.0 or 6.1?
- what is you operating system?
- did you install the entire PC suite, with Titan Mobile and Simulator, or did you deselect all except Titan One?
- can you access the Visualiser from within Titan Simulator?
- close all Titan programs, and try to start the Visualiser as a standalone program (hit the Windows key and type 'vis' in the searchbox, or find it at All Programs -> Avolites -> Visualiser -> Visualiser)
Postby niclights » 22 Nov 2012, 11:23
I suspect this could be similar to the issue on some consoles where the visualiser dialog box is opening on a different screen. After clicking on the 'open' button try using alt+tab to see if there is a visualiser task running that you cannot see.
