hold down a group button on PC
Oz Perrenoud
Postby Oz Perrenoud » 30 May 2025, 07:50
How do I hold down a group button on a PC?
If I use the left mouse button, ok, I see the submenu to use odd, even...random order, but if I release it everything goes back to normal "edit times,..."
I tried the right mouse button, AVO, Latch, but it didn't work.
Re: hold down a group button on PC
Postby Gregory » 01 Jun 2025, 22:52
There is no specific way to do that. As of v18.0 it should be possible to touch the softkey menu buttons if they are on the same screen as you are holding down the group, but not if you are using a mouse. An alternative is that you can use the keyboard shortcuts to select the softkey menu items while holding down the group with the mouse (the shortcuts are Alt+1 through Alt+7). You can also get to the functions by pressing the All/Odd/Even button (or Alt+Down) although in this case they would apply to all the fixtures currently selected and not just an individual group.
Oz Perrenoud
Postby Oz Perrenoud » 03 Jun 2025, 16:08
Great again Gregory!!
Users browsing this forum: No registered users and 72 guests
