Can anyone provide an informed opinion as to whether I could run Titan 10.1 on an Intel NUC which has an Intel Core i5 -5250U at 1.6GHz with 8GB of Ram.
I am currently running 9.1 on this machine but as I have a Titan Mobile running 10.1 on another (higher spec.) machine, I would prefer to have them both running 10.1 as the Titan One is mainly used as a back-up and it would be good if I could use shows from the Titan Mobile in Titan One.
Thanks in advance for any help provided.
PC spec. for Titan 10.1
Re: PC spec. for Titan 10.1
Well i haven’t tried a Nuc, but if you look at the recommended specs for Titan Pc under information/installation notes, it might struggle a bit, depending on ssd or not, and the graphics card in the Nuc. There is a link in information for the Passmark site, where you can check the graphics.
Have read in the forum, that due to the ekstended undo funktion an ssd is a must.
Sincerely
Beast DK
Sincerely
Beast DK
might be a BIT slow but will likely be OK
tho
SSD is REQUIRED for V10+
tho
Most NUCs have a port where an mSATA (or M.2) drive can be connected, which is an SSD. This normally be the best option even though there may be a SATA connector on the motherboard as well.
