I have downloaded V10 and it appears to be working OK. I have noticed that when I shut it down I get a large picture with large text that says (from memory) Pre Release! I thought V10 was fully released. Why does it say Pre Release?????
Confused Steve
V10 Software Release
Re: V10 Software Release
Just an oversight. It should have been removed.
Hi Nicklight
I have downloaded the new V10 yesterday, then I reinstalled in on my machine and this message is still there.
As I said, it should have been removed but wasn't. Despite appearances the cat is harmless.
Sorry, my bad. One thing I did discover though, when you close that window whilst running the simulator (which a lot of my clients do) then the session connection fail. I do think this is not harmless because you need to restart the software in order for it do work again (I have not tried it with a mobile and T1) but with the simulator it does fail. This comment should probably be in the bug section
That window is the Titan Engine so it needs to be running (normally minimized) for the software to work.
