hello all
I'm so new to this software and I just seem to struggle with everything from simple things up to more advanced stuff so I'm probably going to be asking a lot of questions. I have a pretty simple one for you here.
I'm trying too create some quick blackout buttons so that I can clackout certain groups of my lights with the touch of a button. once the button is released I want the blackout to release how would I achieve this
thanks
blackout buttons
oliverst14
linkinalex
Re: blackout buttons
Select your group of projectors, put the shutter value on "closed" or you also can put the dimmer to 0% if no shutter available, then record on a executor button. Then playback option on your executor, and put the relaese from "global" to "dimmer".
You have your blackout for your group of projectors, then you san change the profile of the executor to put it in "flash", "toggle" ect...
This is a good suggestion but setting dimmer to 0% won't work as this is an HTP function. Possible alternatives might be to create a mode 3 playback containing intensity for the fixtures you want to remain on (the others will fade out) or setting the playbacks containing remaining intensity to a high priority and using a button with swop action to kill everything else.
oliverst14
If anyone is interested I'll list what I did to achieve a similar thing. Pretty simple but as a newbie was not sure. My old software used blackout buttons to black fixtures out where as this uses flash button.
I just created different intensity cues for different groups of lights,l along with a 100% all units master. This way I can flash between fixture groups.
Very simple
Very simple
hellbourne24
oliverst14 wrote:If anyone is interested I'll list what I did to achieve a similar thing. Pretty simple but as a newbie was not sure. My old software used blackout buttons to black fixtures out where as this uses flash button.
Very simple
but how do you make it sir i need help on how to blackout on my avolites pearl 2010. i need help. plss hand me a mail lets discuss it.
hellbourne24@gmail.com
hellbourne24 wrote:but how do you make it sir i need help on how to blackout on my avolites pearl 2010. i need help. plss hand me a mail lets discuss it.
This forum is specifically for TitanOne support. If you have a question about the Pearl 2010 please start a new topic in the Avolites Consoles forum.
