Shortcut keys for the blue swap keys
sajansen
Postby sajansen » 11 Mar 2016, 14:13
Hey, im running the TitanOne and im wondering if there is (already) a way to bind keyboard keys to the blue swap keys.
It would be nice if i could use it like this: having a chase running on fader 1 and then you want to switch to fader 2, press a key on the keyboard to swap to fader 2 and then while holding it, do the faders with the mouse.
Sander
djsky
Re: Shortcut keys for the blue swap keys
Postby djsky » 11 Mar 2016, 18:46
It would also be nice to simply FLASH the 10 faders with shortcut keys, or even run playbacks from the keyboard...
For those of us without touchscreen PC's, this is surely an obvious oversight?
sajansen
Postby sajansen » 11 Mar 2016, 18:56
Even if you have a toutch screen display, it would still controll your mous inputs. So its impossible to use the touch screen to press a button AND move a fader with the mouse. so keyboard shortcuts sure would be nice.
sajansen
Postby sajansen » 14 Mar 2016, 12:10
I did found a way, there is software that lets you use midi inputs... but for something this simple... the software is expansive... its called osimidi its 100 euro without VAT just to be able to use usb midi things...but it could be a solution
Users browsing this forum: No registered users and 7 guests
