T1 with capture polar
Has anyone managed to connect T1 with capture polar? if so how do you do it, i understand its done using ARTNET but capture doesn't seem to be doing anything? Can anyone help?
- john rogers
Re: T1 with capture polar
I could use some help with this as well, I'm running it on my computer at the same time...
Have a look here.
None of that helped
Bothering me for quite some time
If you are running both pieces of software on the same machine you may need to add the Microsoft Loopback Adapter which is a virtual network connection that allows applications to communicate with one another as if they were on two different computers. The loopback can be installed using the Add Hardware Wizard in Device Manager, instructions for Windows 7 can be found here: http://www.windowsreference.com/windows-7/how-to-install-a-loopback-adapter-in-windows-7/. Once this is installed, disable all other network connections (wired and wireless) to ensure that the loopback adapter is used by both pieces of software; you will need to re-enable the network connections again before connecting to another computer.
