HI SIR/MAAM i am having a trouble on the fixture i made
generating r20
after i generate it on r20 it save into a rar file and it wont open
then i open the rar file. then it says file unkown. i extract it no file to be extract.
do i miss something on how to use it. but i follow all the guide on the tutorial.
PLSSS HELP ME THNX
generating r20 file savint into a rar
Re: YouTube - Personality Builder Tutorials
dljanqvin wrote:HI SIR/MAAM i am having a trouble on the fixture i made
generating r20
PLSSS HELP ME THNX
It isn't actually a WinRAR file at all. When you install WinRAR, the application installer registers many file extensions as WinRAR filetypes, including .zip .rar .r01 .r02 and so on - including .r20
It just so happens that Avo also use the file extension .r20 and WinRAR has already registered that file extension. In this case it can be ignored.
Just load the .r20 file into your console and if it has been made correctly, it will work.
even if its in a rar file i dont need to extract it or open it ill just need to put it in the console?
i just got bothered by the rar file. i think it will ruin the os of the avolites ^_^
thank you for that info ^_^
dljanqvin wrote:even if its in a rar file i dont need to extract it or open it ill just need to put it in the console?
Correct. It isn't actually a RAR file at all.
Re: generating r20 file savint into a rar
thaank you so much!!!!!!!
Users browsing this forum: No registered users and 1 guest
