Hey folks,I'm new to this and i am looking for the above file for the visualiser,anyone help?
Cheers
Chauvet Q-WASH 419ZLED
Re: Chauvet Q-WASH 419ZLED
You can request Visualiser personalities via the website. Note however that Visualiser does not support White channels or multi-cell fixtures.
Hi Gregory,it is more to have it in the design to show a client.
Cheers
Cheers
I have received your request and will create Vis files for modes 1 and 2 which will simulate pan, tilt, dimmer, shutter, zoom and RGB. As Gregory says it is not possible to simulate (or auto-patch) multi-celled modes (or HSI) so unfortunately it will not be possible to create vis files for modes 3, 4 or 5.
If you are using the multi-cell modes and just want to create some static images for client then you could use Capture Argo in demo mode. Limited to 1hr but if you can patch quickly enough then you can setup some looks and screen capture them. Looks a lot nicer than wireframe for a client.
Thats great thank you,they are running in mode 2 so all is good. Thanks again
