Creating R20 files
Posted: 13 Feb 2013, 06:26
by totalworks4u
Hello there. I have created couple D4 perfectly working files.
What is the correct way to make the R20 files from them?
Thanks.
Posted: 13 Feb 2013, 14:49
Check and adjust pearl wheel mapping as necessary to ensure there are no conflicts or unassigned (marked in red). It is also worth checking attribute type for each attribute while you are here. Go to Wheel Mapping/Pearl tab.
Make sure you give each mode of the personality a unique name. This is set by clicking on the mode and then inputting in the Classic Pearl Reference field.
File/Export r20.
Going by memory I think that should be everything?
