Page 1 of 2
Martin MAC Aura
Posted: 27 Nov 2011, 22:36
by frontal
Anyone got a personality file for this one? I am using Titan V5 on my Avolites Titan Mobile.
Regards,
Kurt
Norway
Posted: 27 Nov 2011, 22:41
Posted: 27 Nov 2011, 23:30
by frontal
Thank you very much :-)
But that personality doesnt show in the Visualiser...!?
Posted: 27 Nov 2011, 23:53
by frontal
When trying to find it in the Visualiser, it doesn show.
Posted: 28 Nov 2011, 00:01
The Vis file has not been written yet. You can request it here
Posted: 28 Nov 2011, 07:37
by frontal
Thanks again :-)
Posted: 28 Nov 2011, 10:59
by john rogers
Hi Kurt,
This fixture is unsupported by Visualizer as it emits multiple light sources, which Vis is incapable of doing.
Posted: 28 Nov 2011, 11:01
by frontal
I understand, but thanks for replying :-)
Posted: 02 Mar 2012, 11:29
by Raúl
Can you make the Aura beam to be controllable from the normal profile?
I want to access the Aura channels (not beam ones) without Unfold the fixture, that's possible?
I'm talking about Titan, I think in classic Pearl it's already done...
Thanks.
Posted: 02 Mar 2012, 12:38
by john rogers
Hi Raul,
There are other ways to select cells without using the Unfold menu. Descriptions of which can be found in this thread: http://avolitesshop.co.uk/phpBB3/viewtopic.php?t=1931
HTH
Posted: 02 Mar 2012, 12:53
by Raúl
Yeah, but they're all very very bad solutions.... right now.
It will be possible to put all channels together in the 25ch mode? as I don't need to change the selection?
I want to select my Auras and have all channels at once... If I only need Aura channels then it's logical to do it as you describe on that post, but if not, too much work then.
Thanks.
Posted: 02 Mar 2012, 12:56
by john rogers
I've forwarded this topic to the fixture support team.
Posted: 02 Mar 2012, 15:32
You can always add an extra mode that doesn't have cells.
Posted: 02 Mar 2012, 15:46
by Raúl
niclights, I just did that and I was about to try it.
Thanks...
Posted: 08 Mar 2012, 11:22
by Raúl
I've just tried it, but the desk seems to confuse Beam and Aura channels on the output, and doesn't work good.
Can you take a look at it?
