POWERSPOT 575 16 CH
Posted: 27 Oct 2011, 16:13
by brian
personality for elation powerspot 575 16 ch needed urgently, thanks in advance
Posted: 27 Oct 2011, 16:49
by icke_siegen
It's in the library: Elation_PowerSpot 575.d4
see http://personalities.avolites.com
Posted: 29 Oct 2011, 11:42
by brian
actually the version in the library is the 15ch version and i need the 16 ch version
Posted: 29 Oct 2011, 12:05
It is 16ch. There is a mistake in the mode name but it will work correctly.
Posted: 29 Oct 2011, 12:08
by brian
actually when i patch the fixture and i try to locate it, it does not, and the home position is not where it suppose to be
Posted: 29 Oct 2011, 12:11
by icke_siegen
Well, the mode is named wrongly: '15 DMX, 16 Bit' - but it's the 16ch mode (the manual doesn't mention a 15ch mode, though):
 <Mode Name="15 DMX, 16 Bit" Channels="16">
    <Import PearlRef="ELPwrSp575" DiamondRef="" />
    <Physical>
      <Bulb Type="" Lumens="" ColourTemp="" />
      <Lens Name="" Degrees="" />
      <Weight Kg="" />
      <Size Height="" Width="" Depth="" />
      <Focus Type="Head" PanMax="530" TiltMax="285" PanMaxSpeed="0" TiltMaxSpeed="0" />
    </Physical>
    <Include>
      <Attribute ID="Shutter" ChannelOffset="9" Wheel="4" />
      <Attribute ID="Dimmer" ChannelOffset="10" Wheel="1" />
      <Attribute ID="Laser" ChannelOffset="16" Wheel="24" />
      <Attribute ID="Pan" ChannelOffset="1,2" Wheel="2" />
      <Attribute ID="Tilt" ChannelOffset="3,4" Wheel="3" />
      <Attribute ID="Colour1Func" Wheel="7" />
      <Attribute ID="Colour1" ChannelOffset="5" Wheel="8" />
      <Attribute ID="Gobo1Func" Wheel="13" />
      <Attribute ID="Gobo1" ChannelOffset="6" Wheel="14" />
      <Attribute ID="Gobo1Rot" ChannelOffset="7" Wheel="15" />
      <Attribute ID="Gobo2" ChannelOffset="8" Wheel="17" />
      <Attribute ID="Gobo2Func" Wheel="16" />
      <Attribute ID="Focus" ChannelOffset="11" Wheel="20" />
      <Attribute ID="Prism" ChannelOffset="12" Wheel="23" />
      <Attribute ID="Effect" ChannelOffset="13" Wheel="53" />
      <Attribute ID="Prism_Func" Wheel="22" />
      <Attribute ID="Effect_Func" Wheel="52" />
      <Attribute ID="P/T_Macro" ChannelOffset="14" Wheel="26" />
      <Attribute ID="PT_Speed" ChannelOffset="15" Wheel="27" />
      <Attribute ID="P/T_Macro_Func" Wheel="25" />
    </Include>
  </Mode>
It must be the correct mode. If you have a specific problem, please name it.
Posted: 29 Oct 2011, 12:17
by brian
ok thanks im heading to the show setup now so I'll repatch and let you know how it goes
