is it possible for some one to make me a fixture profile?
i need a profile for the Showtec pixelbar 12 on a tiger console (not the touch)
i can't get it to work with the 36 channels mode (maybe i'am to stupid for it )
please help me
Specifications
Output
Lumens : 1380
Lux @2m: 3430
Max Distance: 15m
Light Source
LED System: 12 x RGB 3-in-1 3W LEDs
Drive Current: 350mA
Refresh rate: 140Hz
Electrical
Power Supply: AC 100-240V 50/60 Hz
Power Consumption: 45W
Control
Control Mode: DMX
DMX channels: 3, 4, 6, 7, 9, 12, 18, 36
Optical system
Dimmer: 0-100%
Strobe: 0-11Hz
Beam Angle: 40°
Physical
Dimensions: 1090 x 120 x 30 mm
Weight: 4,2 kg
Housing: Aluminum
Color: Black
Power Connectors: IEC
Data Connectors: XLR 3pole
Cooling: Aluminum Housing
Safety
Operation temperature: -20~40°C
Showtec pixelbar 12
Showtec pixelbar 12
To beam or not to beam, thats the question..
Please enter it into the request queue here
If you have a link to a manual please include it in the details as I cannot find one. Failing that please write as much information about each of the modes as possible.
so far i only know the 18 channel and 36 channel mode
18 channel mode gives 2 lights 3 channels:
channel 1 red
channel 2 green
channel 3 blue
channel 4 red
channel 5 green
channel 6 blue
channel 7 red
channel 16 red
channel 17 green
channel 18 blue
36 channel mode each light got 3 channels
channel 1 red
channel 2 green
channel 3 blue
channel 4 red
channel 5 green
channel 34 red
channel 35 green
channel 36 blue
channel 1 red
channel 2 green
channel 3 blue
channel 4 red
channel 5 green
channel 6 blue
channel 7 red
channel 16 red
channel 17 green
channel 18 blue
channel 1 red
channel 2 green
channel 3 blue
channel 4 red
channel 5 green
channel 34 red
channel 35 green
channel 36 blue
- john rogers
In the meantime you could patch this fixture as the Metropolis Met3, found here: http://www.avolitesdownload.com/PersonalityLibrary/?mainPage=Main.asp&ID=1137
This fixture has both 36 and 18 channel RGB modes.
UPDATE
Here is a update for the fixture mode settings.
today i receved 10 units of this fixture so i got the manual
i scanned it and printed it to a pdf document.
http://download.beam-on.nl/pixelbar12.pdf
- john rogers
i am already using that personality file.
and it's working quite wel
http://www.youtube.com/watch?v=SEhaurwM6Yg
The next problem is the other modes of the fixture.
But until then i will use the 18 or 36 channel mode.
- john rogers
maybe it is a id to make some dimmer fixtures with multiple channels where people can use the scroll wheels
Generic 4, 6, 8, 12, 16, 18, 24 channel dimmers
And some options for switchpacks (basic on and off)
it is possible that those are already in the list.
i havend looked the complete list yet
BTW sorry for my crappy english... i'am dutch
Users browsing this forum: No registered users and 6 guests
