Vis files
Posted: 02 Jul 2010, 14:59
				Is this the correct procedure to add Vis files to a TITAN Expert?
Use Personality Builder to create/edit the D file
Save to Avolites/Titan/Fixture Library
Then generate (via Personality Builder) the .R20 file
Save to Avolites/Personalities
Use the .R20 with VisWiz to create the Vis extension
Save .vis to Avolites/Visualiser/Extensions
I'm getting a bit confused trying to get two fixtures to appear in Vis,
I know it's because one of the files doesn't exist. Specifically Futurelight SC780 and Martin Destroyer. I guess if the .R20 is missing then the .vis is going to be as well? Unless one has accidentally been deleted....
Cheers,
Andy
Cheers,
Andy
