Hi. I have bought some LED movinglights from Spark Laser and Stage Equipment in China.
Products:
SPL-LED-030A
SPL-LED-60w Spot
I asked them for an .r20 file to use on my pearl tiger (no touch ) but the files they gave me were for some other lights and another manufactor.
Is it possible for you to make the files I need and send them to me before this friday if I write down every channel info and values here on the forum?
Don´t need palettes.
Console: Pearl Tiger ( no Touch ) Bought in 2007.
Best Regards
Odd Arne from Norway
NEED HELP!! URGENT
Manufacturer: Spark Stage Equipment
Model: SPL-LED-030A (13 Ch.)
DMX
CH1: R
0-255 OFF-ON
CH2: G
0-255 OFF-ON
CH3: B
0-255 OFF-ON
CH4: W
0-255 OFF-ON
CH5: Pan
0-255 0-540°
CH6: Tilt
0-255 0-270°
CH7: XY Speed
0-251 FAST-SLOW
CH8: Shutter
0-7 OFF
8-255 SLOW-FAST
CH9: Dimmer
0-255 OFF-ON
CH10: Color
0-7 NO COLOR
8-15 COLOR1
16-23 COLOR2
24-31 COLOR3
32-39 COLOR4
40-47 COLOR5
48-55 COLOR6
56-63 COLOR7
64-71 COLOR8
72-79 COLOR9
80-87 COLOR10
88-95 COLOR11
96-103 COLOR12
104-111 COLOR13
112-119 COLOR14
120-127 COLOR15
128-135 COLOR16
136-195 FADE MODE COLOR (SLOW-FAST)
196-255 COLOR FADE (SLOW-FAST)
CH11: Pre-programmed
0-127 NONE
128-143 PRE1
144-159 PRE2
160-176 PRE3
177-192 PRE4
193-208 PRE5
209-224 PRE6
225-240 PRE7
241-255 PRE8
CH12: Pan fine
0-255 0-1.75°
CH13: Tilt fine
0-255 0-1°
DMX
CH1: R
0-255 OFF-ON
CH2: G
0-255 OFF-ON
CH3: B
0-255 OFF-ON
CH4: W
0-255 OFF-ON
CH5: Pan
0-255 0-540°
CH6: Tilt
0-255 0-270°
CH7: XY Speed
0-251 FAST-SLOW
CH8: Shutter
0-7 OFF
8-255 SLOW-FAST
CH9: Dimmer
0-255 OFF-ON
CH10: Color
0-7 NO COLOR
8-15 COLOR1
16-23 COLOR2
24-31 COLOR3
32-39 COLOR4
40-47 COLOR5
48-55 COLOR6
56-63 COLOR7
64-71 COLOR8
72-79 COLOR9
80-87 COLOR10
88-95 COLOR11
96-103 COLOR12
104-111 COLOR13
112-119 COLOR14
120-127 COLOR15
128-135 COLOR16
0-127 NONE
128-143 PRE1
144-159 PRE2
160-176 PRE3
177-192 PRE4
193-208 PRE5
209-224 PRE6
225-240 PRE7
241-255 PRE8
CH12: Pan fine
0-255 0-1.75°
CH13: Tilt fine
0-255 0-1°
Model: 60W Moving head Spot
DMX (28 Ch. mode)
CH1: Self-control program
0-15 NO ACTION
16-45 PROG1
46-75 PROG2
76-105 PROG3
106-135 PROG4
136-165 PROG5
166-195 PROG6
196-225 PROG7
226-255 PROG8
CH2: X-axis rotation
0-255 0-540°
CH3: Y-axis rotation
0-255 0-270°
CH4: X-axis fine turn
0-255 FINE TURN
CH5: Y-axis fine turn
0-255 FINE TURN
CH6: X/Y-speed
0-255 FAST-SLOW
CH7: Dimmer main light
0-255 DARK-BRIGHT
CH8: Main shutter
0-7 LIGHT OFF
8-250 SLOW-FAST
251-255 LIGHT ON
CH9: Colors
0-15 COLOR1
16-31 COLOR2
32-47 COLOR3
48-63 COLOR4
64-79 COLOR5
80-95 COLOR6
96-111 COLOR7
112-127 COLOR8
128-255 COLOR MIX SLOW-FAST
CH10: Secondary LED-light dimmer
0-255 DARK-BRIGHT
CH11: R
0-255 DARK-BRIGHT
CH12: G
0-255 DARK-BRIGHT
CH13: B
0-255 DARK BRIGHT
CH14: LED Color
0-7 COLOR1
8-15 COLOR2
16-23 COLOR3
24-31 COLOR4
32-39 COLOR5
40-47 COLOR6
48-55 COLOR7
56-63 COLOR8
64-71 COLOR9
72-79 COLOR10
80-87 COLOR11
88-95 COLOR12
96-103 COLOR13
104-111 COLOR14
112-119 COLOR15
120-127 COLOR16
128-135 COLOR17
136-195 COLOR GRADUALLY SLOW-FAST
196-255 COLOR SUDDENLY SLOW-FAST
CH15: LED-strobe
0-255 FAST-SLOW
CH16: Red 1
0-255 DARK-BRIGHT
CH17: Green 1
0-255 DARK-BRIGHT
CH18: Blue 1
0-255 DARK-BRIGHT
CH19: Red 2
0-255 DARK-BRIGHT
CH20: Green 2
0-255 DARK-BRIGHT
CH21: Blue 2
0-255 DARK-BRIGHT
CH22: Red 3
0-255 DARK-BRIGHT
CH23: Green 3
0-255 DARK-BRIGHT
CH24: Blue 3
0-255 DARK-BRIGHT
CH25: Red 4
0-255 DARK-BRIGHT
CH26: Green 4
0-255 DARK-BRIGHT
CH27: Blue 4
0-255 DARK-BRIGHT
CH28: Reset
150-253 RESET
DMX (28 Ch. mode)
0-15 NO ACTION
16-45 PROG1
46-75 PROG2
76-105 PROG3
106-135 PROG4
136-165 PROG5
166-195 PROG6
196-225 PROG7
226-255 PROG8
0-255 0-540°
0-255 0-270°
0-255 FINE TURN
0-255 FINE TURN
CH6: X/Y-speed
0-255 FAST-SLOW
0-255 DARK-BRIGHT
CH8: Main shutter
0-7 LIGHT OFF
8-250 SLOW-FAST
251-255 LIGHT ON
CH9: Colors
0-15 COLOR1
16-31 COLOR2
32-47 COLOR3
48-63 COLOR4
64-79 COLOR5
80-95 COLOR6
96-111 COLOR7
112-127 COLOR8
0-255 DARK-BRIGHT
CH11: R
0-255 DARK-BRIGHT
CH12: G
0-255 DARK-BRIGHT
CH13: B
0-255 DARK BRIGHT
CH14: LED Color
0-7 COLOR1
8-15 COLOR2
16-23 COLOR3
24-31 COLOR4
32-39 COLOR5
40-47 COLOR6
48-55 COLOR7
56-63 COLOR8
64-71 COLOR9
72-79 COLOR10
80-87 COLOR11
88-95 COLOR12
96-103 COLOR13
104-111 COLOR14
112-119 COLOR15
120-127 COLOR16
128-135 COLOR17
CH15: LED-strobe
0-255 FAST-SLOW
CH16: Red 1
0-255 DARK-BRIGHT
CH17: Green 1
0-255 DARK-BRIGHT
CH18: Blue 1
0-255 DARK-BRIGHT
CH19: Red 2
0-255 DARK-BRIGHT
CH20: Green 2
0-255 DARK-BRIGHT
CH21: Blue 2
0-255 DARK-BRIGHT
CH22: Red 3
0-255 DARK-BRIGHT
CH23: Green 3
0-255 DARK-BRIGHT
CH24: Blue 3
0-255 DARK-BRIGHT
CH25: Red 4
0-255 DARK-BRIGHT
CH26: Green 4
0-255 DARK-BRIGHT
CH27: Blue 4
0-255 DARK-BRIGHT
CH28: Reset
150-253 RESET
Lovely tnx. I will make these for you tomorrow morning. If you can pm me your email I can send direct so you don't have to wait for database update.
Two questions:
In the first fixture do you know what happens on ch 7 (P/T Speed) from 252-255? I think it's likely this is a typo and it should read 0-255.
Does the second fixture have more than one mode? If it does it would be useful to list so the personality is complete for others. It will not affect how long it takes to create.
Two questions:
niclights wrote:Lovely tnx. I will make these for you tomorrow morning. If you can pm me your email I can send direct so you don't have to wait for database update.
Two questions:
Thnx.
The first fixture, ch7 should read from 0-255...
The second fixture has 2 types of lights. It has one light source inside like a regular moving head, but it also has 8 LED lights around the the hole for the main light beam. PM with my email sent
