cell mode library
jacklighting
cell mode library
Postby jacklighting » 01 Aug 2018, 16:29
this dmx channel : i want to write library in cell mode , how i create cell mode 15 cH , pls suggest me
ch1 Dimmer
ch2 Red1
ch3 Red2
ch4 Red3
ch5 Green1
ch6 Green2
ch7 Green3
ch8 Blue1
ch9 Blue2
ch10 Blue3
ch11 White1
ch12 White2
ch13 White3
ch14 Special Effect
ch15 Speed Effect
Best Regard , Sincerely :D
Re: cell mode library
Postby niclights » 01 Aug 2018, 16:36
The mode used for the cells needs to have gaps in the channel offsets. So Red = 1, Green = 4, Blue = 7, White = 10.
In more detail:
- Create dimmer, red, green, blue, white, special effect and speed effect attributes
- Add a hidden mode for the cells containing red, green, blue and white with channel offsets 1, 4, 7 and 10 respectively
- Add the main mode, add dimmer to the master section by holding Alt
- Select the mode.
- Select cells
- Set quantity to 3, select the cell mode and add (it will automatically set the start addresses to 2, 3 and 4 and interleave the controls as necessary)
- Select the master section and add the remaining effect controls
jacklighting
Postby jacklighting » 01 Aug 2018, 16:53
niclights wrote:The mode used for the cells needs to have gaps in the channel offsets. So Red = 1, Green = 4, Blue = 7, White = 10.
In more detail:
- Select the mode.
- Select cells
hidden mode for cell is fasle or true ??
Postby niclights » 01 Aug 2018, 17:07
True.
It is not important. It just stops it from appearing as option when chosing modes during patch.
Users browsing this forum: No registered users and 9 guests
