Winamp timecode, framerate change
Posted: 30 Nov 2025, 16:48
by kkoni
Hello!
I'm programming a timeline and unfortunately I found out too late that Winamp sends a 100FPS framerate. I was able to change the markers in Reaper to 100, but I can't change the almost finished timeline from 30FPS. Is there a solution?
Re: Winamp timecode, framerate change
Posted: 30 Nov 2025, 19:13
by icke_siegen
Don't worry - if you change the timecode source to one with a different framerate the frames are adjusted automatically.
This was erronous in older versions, but if your Titan version is reasonably up-to-date then it should work.
