Intensity view window display absolute values
Posted: 23 Oct 2024, 12:02
by Alexis.A
Hi Avo team !
I would like to know if there is a way to display absolute value of dimmers in the intensity view window regardless of cues or priority.
I would like to show values of dimers as they are on the stage regardless of cues / palette / masters etc...
There is a way to use intensity window as i would like ?
Thank you !
Re: Intensity view window display absolute values
Posted: 24 Oct 2024, 22:26
by Gregory
If I understand the question correctly the answer is no. The Intensity View will show the level as set by cues, palettes or the programmer including any fading between these values however this level is before shape and effect offsets or masters are applied to the level. These latter offsets are processed as part of the conversion to a DMX value and the software does not convert that DMX value back to a level to show in the user interface. This has been requested before so you could consider adding a vote here so that it can be considered against other potential features.
Posted: 28 Oct 2024, 10:26
by Alexis.A
Thanks a lot Gregory.
You understood my question well. Please excuse my bad English.
I will post a vote on the request about this right away.
Thank you for your reply.
