The fixture I need is in my Tiger Touch 2 library but is not available in Capture. I found the needed personality on http://personalities.avolites.com and downloaded it. I stored it on my flash drive and have plugged it into the Tiger Touch 2.
After reading online pdfs and the manual, I still have no idea how to add the personality to the Avo console.
What am I supposed to do?
Thanks!
Adding a Fixture Personality
Re: Adding a Fixture Personality
You should download the file called TitanFixtureLibrary.exe from http://personalities.avolites.com and put it on a USB stick. With the USB stick plugged into the console go to the Tools menu in the top left hand corner of the screen and select Control Panel > Titan Installers > TitanFixtureLibrary and follow the on-screen prompts. You can alternatively go to Tools > Folders, browse to your USB stick and double click on the TitanFixtureLibrary.exe file. Custom personalities with .d4 extension can be put in the D:\Personalities folder. You may need to restart the software on the console before it will display any changes to the fixture library in the Patch View and Patch menu.
If you could say which fixture you are trying to use we could confirm that Capture support is available.
