How to quickly jump to BPM while recording a chase
can i get a tutorial
Re: How to quickly jump to BPM while recording a chase
If you press [Record] - {Create Master} - {BPM} - Select a BPM Master - Assign it to a empty Swop, then exit back out to main screen.
Select Softkey B [Playback Options] - Select the Chase you wish to control with the BPM - a Playback Options window will appear - select {Effects} and change Speed Source from Free Run to the BPM Master you have created.
You will now be able to control the BPM of your Chase using the BPM Swop and fader.
