Hello, i want to connect ableton daw (like reaper) to avolites titan mobile for using midi timecode from ableton software.
I connected audio interface with midi out and midi in cable to avolites titan.
In avolites Titan i set up timecode to 'midi' . I press 'play' in ableton, the midi time code is ticking in ableton but the time in avolites stays at 00:00:00:00.
What exactly am I doing wrong?
Thanks.
timecode with ableton
Re: timecode with ableton
Please try looking at this article and check that Ableton is set to send Sync to your MIDI output, this should make it sent MTC timecode. If this isn't the case it is possible that Ableton is sending MIDI notes/commands instead which you may be able to see and use for Triggers in Titan but won't help with timecode.
