Hi there
I'm not quite sure if this is the right plase, but it seems to be the only one by avolites.
I had an open air festival with 3 avolites powercubes for powerdistribution and dimming. I had to use some of the dimming channels for fixed power. I set the dimming curve to "invert relay" and both DMX and Artnet adresses to zero.
On day three there was some more plugging to do with the guest consoles so we switched from artnet to cupper DMX. Suddently I had values(all FF) on the channels with the zero addresses on one cube. As a result of the invert relay, power was off. Some minutes later, I got the same on another cube.
Now I'm wondering if this is a known problem or if the cubes might be damaged. Did anyone have similar problems before?
Thanks for your ideas
Michael
Powercube: values on parked channels
