Art 2000 anomoly
Posted: 14 Jan 2014, 10:26
				howdy
I have an art 2000 dimmer rack.
Two of the dimmers quit working, so I pulled the module. I found one burned 120v wire for dimmer 10, which took out the control signal wire for dimmer 9, which explains why they didn't work anymore.
Since I didn't have my wire repair kit with me, I removed the offending burned 120v wire and slid the module back into place.
When I turned the power back on to the rack, none of the dimmers on the rack I checked worked. The module is in the proper position, all of it's indicator lights on dimmers that have a load are on, and they turn off when I turn off the breakers for those channels and/or channel groups.
this is weird! Has anyone seen this issue before?
(I haven't swapped modules around- I'm kind of scared to do that at this point!)
