I've timecode a show using winamp (at 100fps)
The smpte source is 30fps, I've noticed the start of the song is in time but it gets more and more out of time as the song goes on.
Is the difference in framerate the problem? If so what's the solution?
Timecode framerate
karenmiranda
Re: Timecode framerate
Are you using mp3 audio files? Then most likely this is the issue - Winamp outputs wrong timestamps. Try to recode the files as wav - this should solve the problem.
