Locate to release color palette
Alexis.A
Postby Alexis.A » 29 Dec 2023, 15:44
Hello.
When I activate a color palette without having selected a projector, the palette is automatically applied to certain fixtures (in Normal, shared or global mode) but is not considered by Titan as program data. Pressing the CLEAR button does not return the fixtures to HOME values. To find the HOME values, i must press LOCATE. This is particularly annoying live or when i use busking method.
Is there a way to disable this function and specify to TITAN that if no fixtures are selected, no color palette can be applied regardless of the mode (normal, shared or global)?
Or, other option, is it possible to specifiy to TITAN that each color palette goes to programmer and can be released by CLEAR even if no fixture was selected when palette was trigged ?
Re: Locate to release color palette
Postby niclights » 31 Dec 2023, 11:55
You can disable quick palettes in user settings -> palettes -> quick palettes disabled.
You can also set clear to release to playback values (user settings -> clear -> release to playback values)
Alexis.A
Postby Alexis.A » 01 Jan 2024, 13:59
Great !
Thank you !
