Hallo, I have used always a midi timecode from reaper drom different laptop with a midi cable.
I was experimenting with ethernet connection settings in dmx settings for realizzer (located on third laptop, separately from titan and reaper ) and suddenly my avolites Titan doesn't receive any signal from reaper midi time code anymore.
Is it possible to check if Titan Mobile is receiving midi signals in the right way?
Thank you.
Titan doesn't receive midi timecode suddenly
alisa.love
Re: Titan doesn't receive midi timecode suddenly
Yes, it is perfectly possible: open USB Expert, (if Titan is not running then start the service at the Tools menu), select the Titan Mobile panel, go to the MIDI tab (top-right)...
alisa.love
I was lokking for USB Expert but didn't find it. Is it abutton on Titan console or in titan software?
Thank you.
Thank you.
On PC go to Start Menu/Avolites/Usb Expert Console.
alisa.love
Thank you, i have found usb expert console and then i press midi.
How to to proceed next?
alisa.love
Is there any way to check midi input connection?
Hi Alisa,
- setup everything as intended (computer running Reaper, USB MIDI Interface, another computer with Titan, Titan Mobile, connected with 5pin MIDI)
- start Reaper and make it send MTC (let me know if you have problems with this)
- start USB Expert console
- Tools -> ACW Service -> Start -- now the Titan Mobile panel and the Titan Mobile Panel should appear top-right
- click on the Titan Mobile DMX Panel
- then, top-right, go on the MIDI tab
- click pn Watch MIDI -> this opens a separate window (the MIDI watcher)
- in this window there are two selects: MIDI Input/Output, and Commands/Raw MIDI. Select Input, and Raw MIDI. Now you can see the raw MIDI timecode coming in:
- when you click on the Timecode tab in USB expert then you can watch the timecode:
Hope this helps
Hope this helps
