Hello
How is it easiest to "factory reset" Tiger Touch
Thinking about selling, or shall I send it as it is?
Factory reset
- Nicke Löfgren
Re: Factory reset
Run a recovery and select 'Full Erase'.
Gregory wrote:From version 10 onwards using the Factory Restore option would be better as it will clear all user data and avoid having to re-license the console.
- Nicke Löfgren
Re: Factory reset
Hello
Do i need a USB stick whit software?
Re: Factory reset
Yes. There should be one inside the console that you can use although it might be an old version.
You can find the recovery creator downloads here. If it's an original non-pro Tiger Touch 1 that hasn't been upgraded then 9.0 is the highest you can go. If it's an original one that has been upgraded or is a pro/Tiger Touch II then you can use version 10. You will need a Usb stick minimum size 4GB (suggest max 16GB, larger can be problematic).
Once downloaded place Usb stick in a PC and launch the creator .exe to create the recovery installer stick. Personally I recommend formatting the Usb stick first with Rufus to ensure it is bootable.
With the console turned off place the recovery Usb in the console and then power up. All being well this should boot from the stick and you can follow the instructions on screen. When the choices come up select 'Full Erase' (note that for v10 you need to select 'Advanced' to see this option).
- Nicke Löfgren
Re: Factory reset
- Nicke Löfgren
Re: Factory reset
Everything has gone perfect
But after I got new license from avolite you want the console does not change from the temporary license!
Have changed different USB stick and imported, the same error. Temporary licencs
Re: Factory reset
I think that might just be a display error. Try power cycling the console and see if it fixes.
- Nicke Löfgren
Re: Factory reset
I have restarted the console several times
Users browsing this forum: No registered users and 95 guests
