Teach me how to do make lights do this....
OK, i'm running on the titan mobile. My question is if I have all my movers on, is there a way to turn them all off 1 by 1 really fast like in a 3 sec time frame? So basically I don't want all of them off at once. The scene i want is all lights are on to pitch black in a matter of a 2/3 secs and then to blast again. Could you teach me to do this? I use this board every week, but would still consider myself a newbie, Thanks for your time!
Re: Teach me how to do make lights do this....
No problem.
The first ting you have to do is to record a group in the order you want your dimmers go on ant off.
If you have done that you can program teh cue's.
- Select the group;
- Set intensity to 100%;
- record cue;
- set intensity to 0%;
- record cue;
- Finish record [Exit]
- Open playback view [Open Window ,] select playback by prssing the blue button of the playback fader or select it in the playback workspace
(depents on where you programed it.
- In the playback View you have to set the Fixture overlap and Fade in.
- Set the fade and overlap for both cues
- For diferent effects play with diferent times ( fade in / fade out) and Fixure overlaps.
After trying this on the Intensity atribute start trying it on other atributes for example the movement.
use the 2 stap cue list for intensity.
- record cue 2 all movers up ( your old cue 2 is now cue 3);
- record cue 4 all movers down;
- Set the fade and overlap values;
- for cue 2 and 4 , Set ling to 'Link with previous cue
good luck
No problem.
- Select the group;
- record cue;
- record cue;
good luck
Great! Much appreciated, I will give it a whirl!!
XAVIAVOLITES
En verdad no se donde dirigirme para efectuar una consulta a JAVIER.
Where can I write to contact with Javier in Spanish?
I believe Javier keeps an eye on the Spanish section of the forum. Or you can find his contact details here.
