Midi controller to titan simulator
Jaredwilliams
Postby Jaredwilliams » 25 Jan 2013, 10:04
Hi, i wish to do some offline programming on my windows 7 machine.
I would like to connect my midi keyboard and set-up some triggers.
As my pc only has a usb in and not also a midi in like a console would.
Can i in anyway get the software to see the midi commands come in via usb.
My midi keyboard has both midi din out and usb out and i also have a midisport 2x2 anniversary edition usb to midi interface if this can be of any help? Thanks
Postby niclights » 25 Jan 2013, 12:35
Unfortunately MIDI is only supported through Avolites hardware at the moment. Sorry.
Jaredwilliams
Postby Jaredwilliams » 25 Jan 2013, 13:00
Ok! Would it not even work if the midi signal was transmitted via artnet? Thanks.
Postby niclights » 25 Jan 2013, 17:32
Artnet is not currently supported as a Trigger input in Titan as far as I know. If you are wanting to pre-program triggers then you can still do this manually, you just can't use the learn function. Options are standard MIDI or DMX. Both require hardware (ie. TM, TT, PE, ST) to use.
